OUTBOARD REPAINTING
CLICK7
Can i use the the same omc paint for lower units<br />om my fiberglass engine cowling, if not what is the best paint for the cowling?
Re: OUTBOARD REPAINTING
"Can i use the the same omc paint for lower units"<br /><br /><br />Ayuh,............. You Sure Can..........
Winger Ed.
That's what most folks do unless it stays in the water more than a few days at a time.<br /><br />Just do your surface prep. real well, use good quality primers & paints. Preferably materials that are catalyzed.
flashback
I have an old honda kicker that I sprayed with silver rustoleum several years ago.. It has held up amazingly well and the engine is out in the weather all the time.......... :D Can,t say much for the rubber gasket tho... :D :D
CLICK7
Thanks for the help,Im new to this post fourm<br />so please bear with me, There seems to be alot of good info here1
Solittle
I did mine last year:<br /><br />
Realgun
So little that looks good but the OLB is showing :) O.L.B. Old ladies butt. Thats Orange peel to the other folks. You should wet sand it and then paint another Light coat on it.<br />Personally I think it looks awsome. And you have 2.
tengals123
solittle, what did you do??<br /><br />1. clean<br />2. sand<br />3. actone clean<br />4. prime<br />5. 2-3 coats<br />6. 2-3 coats clear<br /><br />let us know, looks great
Mark42
Solittle,<br /><br />Did you take pictures along the way? A link to them would be nice. I like the outdrive design, especially from the interior space savings.
