I'm trying to fix an Idle problem in my carport, I stuck a 32 gal trash can under the motor and filled it with clean water, after running 5 to 10 mins the water is filthy. Is this normal?<br /><br />Mike.
Probably, Filthy of what? It is flushing your cooling system so what ever deposits are in it are flushing out. Also your exhaust is coming out in there
I regularly use a large 100 gallon tank to run my engine. Easier than muffs as I know I am getting a constant supply.<br /><br />Quite normal for the tank to get slimy with oil deposits as the exhaust vapours mixed with oil soon turn a clean tank to something unhealthy looking.<br /><br />NG
Rod Knocking: There's one in every crowd, Gotta admit though... that was pretty good. Thanks to all, you guys are great. Thanks for your support and assistance.
