outboard runs but will not run faster than idle speed
bigmen905
I have a 1979 Johnson 25hp outboard. I took my boat on a fishing trip, it started out fine but after a few days the engine would rev up but the fastest my boat would go was idle speed. After I got past 1/4 throttle the engine would continue to gain speed but the boat would not. What kind of problems should I look for and are they going to be worth fixing?
NathanY
Re: outboard runs but will not run faster than idle speed
Sounds like a spun prop hub.
bigmen905
The shear pin was not broke. Do you think a lower unit problem?
St. Bennett
Did you take the shear pin all the way out? Sometimes th pin can shear off in more than one spot. If this happens then what could be happening is the shear pin looks fine but there is no middle to it. Centrifugal force can alter this.
bigmen905
I removed the shear pin and it was still solid. I then replaced it and had the same problem.
Walker
1979 would have a rubber hubbed prop. I agree the hub is spun. Need to have it re-hubbed at a prop shop.
bigmen905
How much do you think it should cost to have this done? What do you think the normal shop rate should be I have had some questions about how much the dealer has charged me in the past.
roscoe
About $40. <br />Do you have a spare prop? If not now is the time to buy one. Then you can use it until your prop is fixed.
