Outboard sound insulation
Is it worth it for me to put sound insulation on the inside of my Force 85hp outboard engine cowling? From all the old adhesive left, it looks like it had some at some point in the past. Will I notice any difference in the sound level? Is it too risky in case some bits fall off in the future and get sucked into the carbs? Will it restrict airflow around the engine?
Thanks,
Pete
Bob_VT
Re: Outboard sound insulation
All 2 stroke outboards are loud..... depends on the use of the boat. If you are fishing I would not bother. If you are trying to hold a conversation with people and you do much cruising around it may be worth a shot ....but do not expect miracles.
Are you running the silencer boxes over the carbs now? I have seen many people who just do not re-install them and yes the motor is even louder. Factory insulation will not restrict your airflow but the sun beating down on the cover will loosen it pretty fast.
Chris1956
I would think that installing new insulation would be a good idea, if it is not too expensive. You might consider the foil-backed self adhesive insulatation used on heating ducts. A second choice is that bubble wrap stuff made from Mylar.
Frank Acampora
The original sound deadening was a black open cell foam. It tended to get crumbly with age, break up, and clog the carbs, so most pre-Merc. Force engines will have it removed.
Any oil resistant sound deadenig insulation will help some with the noise but don't expect miracles. The main air intake is under the steering snout and a good amount of noise will come from there no matter what you do.
The air box in front of the carbs does nothing to dampen sound. Its function is to capture "spit back" from the carbs and recycle it to the intake manifold.
pecheux
I find that my 15 hp Force (1997) is louder than any other OB that I ve seen yet. I like the idea of using the foil backed insultation as per Chris1956 suggestion. But I do wonder if there is enough room between the cowling and the motor itself ? Anyone knows the clearance space ?
Tx
ddrieck
I installed the sound dampening material they use on surfaces when they install those high dollar car audio systems. I believe it is called Dyna-Mat. I got mine from Best Buy but most car or home audio dealer will have it in some form or another. That stuff works awesome at reducing the sound level under the cowl on my 1976 85hp Johnson V-4. Its about 1/8'' to 1/4'' thick and has a self adhesive back. The stuff I installed has not even come close to releasing from the cowl due to heat from the sun and motor. However, be warned, it is expensive.
pecheux
Sounds like a plan ... thank you
pecheux
Hi Frank, On my small 15 hp Force kicker there is nothing in front of the carburator air intake ... just an air sucking hole in oposition to my Johnson that has some sort of plastic cover that allows indirect air breathing. Since I plan to use sound barrier material would it be a good idea to have some sort of screen covering the air intake hole to prevent any foreigh material to get inside the carburator ??? would it prevent the motor from operating properly ? TX
Frank Acampora
That's one reason Force engines are cheaper than OMC.
A LONG time ago (on a planet in a different solar system--or some such, been a long time since I saw the movie) 1950s OMC engines had a perforated screen in front of the carb on the two cylinder engines. Older Mercs used a plastic grate in front of the carbs.
If you use a big enough hunk of screening, massive enough to resist corrosion and crumbling that goes with it or stainless screening, with a high percentage of open space versus wire, the engine should run very happily.
When in doubt, measure the venturi diameter. Venturi is the narrow part inside the carb not the outer opening. Area = pi R squared. 1/2 diameter times 1/2 diameter times 3.1416 is the area, let the screen open area be equal to at least a MINIMUM of 10% more and greater is better.
pecheux
Got it ... thank you Frank. now I need to do is find something that will fit with those specs in mind. LOL Now that you've mentioned it I do remember the black plastic piece that was mounted on the Merc OB's .... rather big spaced screen type ...
pecheux
I am curious ... how can silencer boxes make the engine louder ?? May I ask just where is the sound coming from on a small OB ??
ddrieck
On a older 2 stroke engine there is always a certain amount of back flow (fogging) that will come out of the carbs. With this also comes the exhaust note of the engine. This is caused by that very brief moment when the piston is in between the intake port and the exhaust port.
Therefore, a 2 stroke will have a silencer box installed over the carbs to deaden the noise coming out of the carbs.
pecheux
Thank you for the info. Is this silencer box a universal part or per OB specs ? I have a 1997 15 hp Force and would like to install one of these silencer.
Which brings another question to mind ... the cowling seems air-thight so where does the carb pick up the air it needs ?
Have a great day
pecheux
Hi, showed up at Best Buy and they had no idea what the Dyna Mat product was .... any other big stores you could suggest ? Tx
pecheux
A clerk from Home Depot guided me back to Best Buy and advise I would go directly to the car audio dept. ... they had the material ... bought it .. LOL ... will install before spring OB activities ... LOL
pecheux
May I ask ... did you cover every inch of the cowl or just the main areas where the dyna mat pieces would fit ? Tx
ddrieck
I covered the entire inside of the cowl except where the air intake vent was located.
