My steering is working just fine, very smooth, no issues.
However, the boat is new to me, and I am slowly getting it in good shape. Next project is maintenance on the steering system. I went to disassemble for cleaning / lubrication and found what is shown in the attached pic.
Questions:
1) Side where the cable enters the tube -- the nuts are corroded. Started to loosen, and the cable turned with it. I stopped. Options / recommendations on proceeding? I'm considering just letting it be and working to clean / lube from the other side only. Not optimal, but don't want to create more of an issue by disassembling. If disassembly makes sense, replacement nuts?
3) Quicksilver 2-4-c OK for lubrication?
Motor is a 1998 Ocean Pro 150.
Thanks!
Questions:
Thanks!
