Re: Outboard tilted position during winter
kkilloy......If this is a lake, then it must be fresh water, correct? Leaving the engine down will be fine. I would change the L/U oil before winter, to have fresh lube in it and be sure there's no water in the LU, then just leave it down. If the lake never freezes then it will be fine, even if the air temps drop, the water will be warmer than the air.
frankina......your best bet is to drain and re-fill the LU before winter and then leave the engine in the water and get a bubble system if possible, and just deal with lifting the engine and taking a brush to it once every couple of weeks. I leave my boat in Montauk until January and start leaving the engines down in late Nov. I get very minimal growth and the water is warmer than the air. There are at least 10 boats on my canal that are in year round with bubblers.
