87 mercruiser 260/350 5.7 Alpha 1 gen 1,
long story short , i got this outdrive from a guy at my marina, he said it works and he did a pressure test and replace water pump and it only needed oil , this is 4 years ago i put oil in it 4 years ago but never put it in the water, sat there for 4 years , im installing a new engine and i was ready to install the outdrive but i said to myself i better do a pressure test just in case so i drained the oil to proceed but the OIL CAME OUT BLACK. Took it apart and of course he never serviced the lower , it had sand and the housing was in very bad shape , So before i go and buy the water pump kit to replace it I need to know what the black oil mean, it was fresh and new when i put it in.
Also if anybody can tell me if its even compatible with my engine I know is an alpha 1 but not sure the ratio. here's the serial # OB663011
As always Thanks in advance.
