89cruisers
- Joined
- Jul 11, 2005
- 190
Hi:I accidently put this with the Mercury section so if you see this in the Mecury problems forum it is supposed to be here. I have a 1989 Cruisers Holiday 2670 with dual 3.7 4 cylinder Mercs. I started it up the other day like I usually do (put the muffs over the intake vents on the outdrives and turn on the water hose)and went to the helm after both engines were running a few minutes I started smelling somthing and the tempature guage was rising on the starboard engine so I turned them off and when I started the starboard one again water wasnt coming out of the holes where it usually does and it seems to over heat, this is a closed cooling system but I know that water is still needed to cool other components. Iv always started this boat and my past boats the same way before and never had a problem. do you know what is wrong. Thanks
