Re: Outdrive drained, can I run in neutral
Haut Medic - I have the bad habit of taking things apart and forgetting how they go back together!!
I'm down in Puyallup, any recommendation for a good OMC shop in the area??
Also - My service manual says the gear drive should "Only be filled with OMC Hi-Vis gearcase lubricant", will any gear lube work? Does it have to be marine specific, I have 75-90 for a car rear end, will this work?
Thanks.
