Outdrive Fitment Question
SNSTER
I have a boat I am planning on restoring with a whole new driveline. I have already Installed a new built 383 stroker some time back. Now wanting to do a full restore with a new updated outdrive. My question is the boat currently has a Volvo 280 on it. I am considering changing that out to a volvo penta Cobra SX. Will the hole in the transom be the same size for both outdrives? I know the transom plate and everything will have to be changed. This might be a silly question or just some wishful thinking on my part. Thanks
D.J.
bruceb58
Re: Outdrive Fitment Question
The hole that you have is bigger. If the drive that you have is working, I would stick with it. Those 280s are awesome drives.
SNSTER
One I dont think it has the gearing I need. Trying to get this boat into the 70 mph range and its only in the mid 50's with a 23P prop. I have had several problems with this outdrive already and would like the reliability of a newer unit. Parts are also very expensive for it and hard to find.
bruceb58
You are talking about rebuilding your transom to use a newer drive though. Not an easy task.
SNSTER
So if I rebuild the 280 is there a way to change the gears in it to make it more desireable for me to use?
bruceb58
That is a DonS question as I am not sure if those are in the upper or lower. What size boat is this on?
SNSTER
Pretty sure they are in the lower. Its a 24' and ugly hence the restore lol
sqbtr
They are in the lower, show a pic of that sweet 280T
sqbtr
+1 on the DP
SNSTER
Ok so what is the best way of going to a duoprop on this outdrive? My other boat has a DP but it has a b3
SNSTER
Anybody have any ideas on the DP or gear change?
Don S
You can change the lower unit to change to a DP. They are so much better than the Bravo III drives you won't even believe it.
SNSTER
I was hoping you would chime in Don. Exactly what is the advantage to the duoprop vs. a single? Is it just the better maneuverability? What gear ratios are available in the DP? Hope you dont mind me picking your brain
Don S
Small blocks run the 1.95, big blocks normally use the 1.78.
The DP's are only rated at 50 mph drives, I know of a few in the low 60's. 70's ????
25% better efficiency, fuel milage, and getting on plane, better control. Other than that, they are about the same as a single prop.
