Outdrive fluid---What is milky?
mike11374
Got the boat home today 1991 Caravelle, 4.3L OMC Cobra Outdrive. She started right up on the muffs with no problem. Didn't engage the propeller, just ran it for a minute in neutral. Then checked the outdrive fluid and I'd describe it as green and frothy. Many air bubbles. Is that what you folks mean by milky? If it is, I know that means water in the drive but how do you determine which seal to replace. Aren't there many? How much cash am I looking at to fix this? Any thoughts would be greatly appreciated.
lilmandavis
Re: Outdrive fluid---What is milky?
some fluids are green. water intrusion is whitish. pressure check it<br />5to 7lbs of air is good. make sure that the air supply line isnt leaking with soap and water
jch7450
Last time i had all the seals replaced was around $800.00 or so, Is there any metal shavings on the drain plug magnet?
mike11374
It's definitely not white in color, it is green and seems to have a lot of air bubbles in it. Any thoughts? Is that normal?
mike11374
I just wonder whether the water that is the drive is from condensation over the winter. Is that a common thing? I would think that some condensation does develop with the changes in temperature. Any thoughts?
tommays
there should be NO water at all if there is something is starting to leak <br /><br />So far you have said it has air bubbles what makes you think its got water ?<br /><br />tommays
mike11374
The color looks fine....green. But the fact that it is kinda frothy is what has me concerned. Should I not be? Everyone on here says it will be "milky" white if it has water....that is definitely not the case here.
