mtsinner7868
- Joined
- May 9, 2012
- 27
Pulled and took my 888 out drive apart as I have to replace the water pump and motor. From what I gather in my research, my lower unit seems to be an Alpha 1 (first gen) as it has no pre-load pin on the drive shaft and the cavitation plate is square. And my upper is an MC-1. Am I correct in what I am seeing in these photos and my terminology ?
So I now assume Alpha 1 (first gen) and MC-1 uppers/lowers are all interchangeable ? If not please set me straight. Now for the water pump I have to replace, is it the same pump in both lower units or are they different for each ? And I'm seeing that there is no difference in bellows between the MC-1 and Alpha 1 (first gen) drives correct ?`
