Re: Outdrive issues
I agree, I may be nearing the point where I have to take it to a pro. However, (I'm sure you knew that what coming!) I am trying to accomplish as much as possible by myself (with the help of the manuals and people like yourselves) for the satisfaction of learning how to do it and do it right. My merc manuals are on their way, I'm struggling with the Clymer's for now, I've got the tools, and again I really appreciate your help and patience. <br /><br />Here is an update; First , I think I caused some confusion about The "retaining nut" the book refers to it as a retainer. It holds the u-joint assembly in place in the upper housing. When I backed it off I was able to turn the assembly. When I removed it completely, I found that the metal outer ring of the oil seal was damaged. It has 2 "rips" in the metal that the universal is getting caught on. I will replace the seal and the o ring and put it all back together with a new nut (tightened to specs) on the gear assembly.<br /><br />I'll keep you all posted. Joe
