SS MAYFLOAT
- Joined
- May 17, 2001
- 6,372
I have a 280 Volvo Outdrive, so far it is quiet and smooth. It wasn't used for several years. The lube was clean and free of any metalic particles. The universal joints of the input shaft seemed tight, but free of any binding. During the last time I had it out, I noticed a vibration and somewhat chattering in the outdrive when I turn the outdrive in either direction. It did this when I first started using it, but it happened only when the outdrive was turned to the max in either direction. Now it has started doing this when the outdrive is turned to about 40% in either direction. I feel that this noise and vibration is due to the joints going bad. Can anyone confirm this before I start into the removal of the outdrive? Thanks again for the help
