outdrive knocking
boatdoc
87 140, alpha one.trim down full right deflection is when it does it.dont think its gimbal or u-joints,replaced both already.....almost like its making contact in the bell housing also its not as prevelent at idle,around 1500 to 2000 is when its bad.pulled drive, inspected,no fresh marks as i can see....has got me baffled...
kwoolard
Re: outdrive knocking
Have you checked the outdrive/engine alignment?
hoot
possible the u-joint cups are hitting the nut? maybe the cups aren't pressed down all the way. shift cable needs adjusting? could the sound come from the lower unit and transfer up into the housing?
boatdoc
first thought was u_joints,found no contact points on the nut.guess its possible for sound th telegraph up but not likely since it only sounds off in a right turn
boatdoc
update:finaly found the engine had been out before,big suprise huh,someone "forgot" to install rawhide washers and spring spacers....threw the whole alignment out by a mile....addressed that and its all better now...tks for all the input...
Boomyal
Originally posted by boatdoc:<br /> update:finaly found the engine had been out before,big suprise huh,someone "forgot" to install rawhide washers and spring spacers....threw the whole alignment out by a mile....addressed that and its all better now...tks for all the input...
Rawhide washers? Boy am I glad I have an OMC Stringer. It doesn't require any saddle tack to keep it operating. :p ;) :D
boatdoc
auctually boomyal,their not rawhide but a highly sofisticated,nasa approved co-polymer material that has been designed to handle the rigors and stress of the marine envorinment.they just look ,smell,and taste like rawhide...and just think of all the cattle brunswick are sparing....
