rfdfirecaptain
- Joined
- Aug 17, 2008
- 314
I noticed a little sheen on the surface of my exhaust water today. I shut the engine down and then noticed a steady drip of gear oil from my exhaust chute, onto my aft prop. I raised the outdrive fully just to contain the drip. I looked down inside the exhaust chute and saw a puddle of gear oil, about an ounce. The puddle isn't getting any bigger, but there is an obvious leak when the props are turning. I guess it's safe to say this outdrive will fail a pressure test.
I have attached an overall photo and another photo with a red arrow pointing toward the exhaust chute, which is where the oil is dripping from. There are no exterior oil leaks on this outdrive. Although the oil is dripping from the exhaust chute the actual leak appears to located be up inside the exhaust chut somewhere around where the upper and lower gear housings are bolted together. Now the question is how do I fix it? Does anyone have a shop manual and plenty of advice on how to proceed? Some step by step instructions would be even better.
Hey, if you gotta beg for help, go big!
This outdrive is a Volvo Penta DP-D1.
