followme21
- Joined
- May 19, 2008
- 65
So my brother-in law has a 1992 Four Winns with a OMC outdrive on it. Last summer he went to check the oil level in the outdrive and as he took the top fill plug out he heard something fall down inside the outdrive, like a piece of metal of some sort. He didnt drive it after that but we want to get it running again. I have had my lower unit off of my 85 merc and it looks to nearly the same. And I have a book to help me out.
My questions is what was it that fell??? the hole that is there in the outdrive is plasic, looks to be an insert into the metal casing of the outdrive, was there a metal washer type thing that the plug threaded into that just came loose from the inside of the outdrive? or a nut or what?? And is this a factory set up or has someone along the lines cobled it together??? What should be done to fix the problem????
Also I plan on removing the lower unit to remove the "piece" that fell down will I be able to get to it from there or is ther a better way???
Its not located near me at the time so I cannot get a photo to help explain. Any help would be great.
Thanks
Thanks
