Outdrive oil Frothey
chaddeems
My outdrive oil is new and when checked after 4 hours of running the oil is not discolored but it is frothey. Is there something wrong?
chaddeems
Re: Outdrive oil Frothey
yeah. when i filled it i checked the level and it was full. i first noticed it was frothey after i had the water hooked up to the engine and checked to make sure everything worked so i ran the outdrive for a few seconds. after i let it sit and then checked the level again and that is when i first noticed it. the oil is still clear and not milkey but i just dont know if this is normal. After we ran for 4 hours i let it sit and checked the level again and it was frothey still. Any help.
chaddeems
Does anybody know what might cause this or if it is bad?
chaddeems
Also there was a little bit of metle in the oil. I know everything inside is good because i just got done tearing it apart to check and then re-assbebling it.
