Outdrive oil reservoirs
Grayhorse
Been considering oil reservoirs for my twin 140's, but don't want to spend the bucks for new kits. I have a couple of industrial 2 pint oil reservoirs, but need ideas as to the mounting. I am assuming the reservoir must be mounted at exactly the same height as the vent screw on the upper gear case. Any help appreciated.
qystan
Re: Outdrive oil reservoirs
The kit instructs to drill the transom through hole at 8 1/4" to the port of the centreline and 1" above the top edge of the transom assy.<br /><br />The bottle bottom will be above transom hole. Means you will be a few inches above the vent plug.
