trying to figure out if I need to change the outdrive oil this year. It was changed at the start of last season. I only had a 1 month boating season as the lake completely dried up. It was docked in a wet slip for the one month. Will last years outdrive oil be ok with very limited use, or should I change it again this year. I am under the impression it has to pumped into the outdrive, so I would assumre some kind of pump kit is needed if I need to change it. I used to have my mechanic do everything, for the last 13 years, but I believe it's time to start learning to do some of this stuff myself to save some money. My mechanic, who was once very reasonably priced, has now priced me out of the shop.
