Outdrive Paint & Prep
Galvez83
I have been reading up on previous post but cannot seem to find the answer. I am preping my DP for paint. I do not have Alodine or Alumaprep. The outrdrive will be sanded for paint. I only boat in saltwater. I will try to keep as much of the factory paint as possible. The question is 2 fold....
  • what primer to use on bare aluminum (zinc or self etch)?
  • On scuffed but still painted parts, what primer to use?
All will be done with spray can. For the paint i would like to go with a Volvo Penta matched 2k paint and 2k clear....is that acceptable?
BRICH1260
I`ve done mine for Fresh water. Used Zinc Chromate self etching as a primer and Volvo SX Silver as paint then sprayed Clear over that. it worked for me in fresh water, not sure if being in salt is different.
Scott06
I would look at an epoxy primer like PPG DP 90 yes the 2 k is good. yes the 2 k is good. I would look into the alodine and alumaprep as non fo the rattle can zinc primers made for this application I have used stick better than the factory stuff.
You dont have to use primer over the scuffed paint but if you are spraying something like the epoxy DP90 that can go right over. Find your local autbody supply house and tell them what you are doing they can set you up.
I did expensive primers and the Moeller rattle cans of zinc dichromate.
Both are OK, both work
Rattle can paint isn't as hard or good as rustoleum with a hardener.
My latest process is hardened rustoleum sprayed with a harbor freight gun top coated with a rattle can of clear for shine. See the later pages of the thread in my sig
Galvez83
Hi all, so went with rattle can 2k paint and clear. Since i dont have a spray guns and compressor i stopped by my local auto paint supplier and they mixed and prepped the paint. Will get to painting today if the weather clears up.
Scott06
Are they able to mix up paint and fill rattle cans ? If so that is great
I think you will find finishes from and automotive paint supplier will be more durable than the typical off the shelf rattle can. 2 k systems are much more durable. I painted my 1965 Pontiac about 30 years ago, car was covered with surface rust from sitting for over 10 years. Sandblasted and first coat was PPG DP epoxy primer have had very little bubble back of the corrosion . Certainly a different application but clearly the finish is much better
Galvez83
I spoke with paint guy and he advise to only go with the 2k rattle clear. He did mix up my paint rattle can as well, from a sample. Bell housing and trim rams are done. Its not work of art but as long as its protected i am good with it. Moving on to the outdrive and the transom shield.
Chris1956
Are you planning to use antifouling paint? Doesn't sound like it. If I didn't use A-F paint on my MerCruiser, it would have been all barnacles.
Zinc chromate is the best for bare aluminum. Most antifouling paints for aluminum recommend a good barrier paint to protect the aluminum. V-P paint is fine for that, as are most decent enamels.
Galvez83
No anti fouling. Boat is trailer kept
Donald0039
So on a trailer there is really no corrosion to protect from. It's a matter of how much time and money you want to spend on painting the outdrive.
Chris1956
If it were me, I would find some aftermarket paint that matches the V-P color, and a can of Zinc Chromate primer and sand, prime and paint outdrive at the beginning of the season. V-P, Merc and the others charge way too much for "factory" paint. Since he trailers the boat, he can repaint the OD after every trip that he rubs it off, if he desires.
vroom ZOOM
Here is my experience:
the alumiprep alodine is generally the best way to go, BUT...
Here is what I did last time to paint my seadoo jet pump nozzles (paint stuck really well)
1. Sandblast or clean up the corrosion REALLY well. Brass brushes only, no steel brushes as those could leave metal deposits which could rust. You could also buy a wet blasting pressure washer attachment really cheap and a bag of crushed glass. No dust, and cleans out the pitting quite well.
2. Fill pitting with JBweld and sand smooth.
3. I got some self etch primer from a local cdn tire. (basically the green stuff). I painted over the bare metal areas with it.
4. spray your favorite colour on. I prefer a single stage paint instead of BC+CC. Here is why: The single stage paint is basically a single layer of hardened urethane. If you scrape some paint off the front of your skeg for instance, I found that the BC layer is weaker, and the dynamic pressure of the water hitting the exposed BC wants to peel it off. Also worth mentioning that merc recommends painting with single stage as well (I think its deltron concept)
boatdude100
Question about above for V.P outdriver. Should the JB wield perhaps go on top of a first layer of primer as the primer is corrosion prevention? If so, would it (or marine tek) stick well to a primer? like self etching primer CDN tire or alodine?
Also, Zinc chromate primer is no longer available or shipped to Canada, any substitute suggestions? Is Zinc Phosphate a good second?
Chris1956
You want the epoxy putty to be applied to bare metal. Sand the OD, wipe with acetone and then quickly apply the putty. After it sets, sand smooth and prime with zinc chromate or etching primer.
