Re: outdrive plug on cobra
thanks for the reply. it is the one your thinking of. the previous owner must have removed it because i didn't. sad part is i resealed everything and filled with gear oil, installed the drive on the boat and started it before i realized water was pumping out the side and not to the engine. i double checked after reading the link that you provided to another thread(thanks), and the omc manual doesn't even mention this plug in the upper housing section. i guess it's ingenuity time, there is no mention in the manual, no pictures of it on any parts diagram, and i'm not buying a used outdrive just to get this part. hopefully i can find a solution.
thanks
duane
Ayuh,.... It's merely a ssteel screw, 'n ssteel nut,... Donno the size though,...
The Big Problem with the ole OMC Stupid Screw, is puttin' the nut on the inside, requires splittin' the upper from the lower,...
'ell, the nut may well still be bouncin' 'round on top of the lower,...
I imagine you could epoxy it closed,...
