I have a question regarding a screw I took out on the outdrive of my OMC. The screw I took out, I thought was a water darin, it is on the port side and is just behind the mounting bolts. There was a plastic gromet and there is a large flat nut on the inside. I am just wondering what this is for? Like I said I thought it to be a water drain so I took it out but when I went to put it back 1. the gromet broke 2 the nut fell down inside. I pulled the outdrive to change oils and seals and managed to retrieve the nut. I guess I am looking for the info on this gromet, where can I get another and what it is all for.
Thanks for any help.
