ConnieMarie
- Joined
- Apr 29, 2014
- 44
Not to beat the topic to death but I cannot for life of me get my outdrive back on. My alignment tool goes in easily and I can rotate with two fingers. When I measured distance from gimbal bearing it’s about 15.25” to the end of the tool. I don’t think I can possibly get the bearing in any further so don’t believe that’s the problem. Everything is lubed up good I basically get it on to the end of lugs and that’s it...so it needs to go on another inch. I pulled it out a couple times and retried. Looking at the grease on the spline looks like it was in about an inch and that’s it. I tried changing gears on the outdrive forward reverse that didn’t help. Do I need to get inside the boat and shift gears? Also how does one move the ujoints? I was thinking maybe if I could twist slightly maybe that would help...would I have to detach hose clamps on bellows transom side for this? Really doing a number on my back wrestling this thing around and am just stumped. Any help appreciated and again I apologize for beating the topic to death all I could find are alignment issues which don’t seem to be the case here.
The drive is a vp sx-m1.51
