Re: Outdrive Reservoir Kit
Yes, they do work.
You can see if your outdrive starts leaking oil, the level drops in the bottle, not in the drive, and you don't end up with dry gears in the upper.
If your drive oil gets water in it, the gear lube in the reservoir will turn start turning milky.
