1996 5.0 Volvo Penta Duo Prop
At times when tilted up (not all the way) even if in neutral the outdrive goes into a scary shaking back and forth causing stering wheel to rotate back and forth violently and shaking entire boat. This stops if trimmed back down or engine is shut down. If retarted with drive trimmed down the problem does not repeat.
The drive is in very good condition. Was totaly rebuilt last year. Problem existed before rebuild and after.
What could be causing this?
