Outdrive spray vs Brush on..Please respond
pbuzz3323
Just used the interlux spray but want to hear other boaters experiences with the spray as well as the brush on trilux 33 brush on...PLease post your results here..Im trying to decide if maybe I should brush the 33 on but Ive already used the trilux spray and Im waiting to put it in the water. I used the Primocon prior to the spray....Also..Im considering doing My SS props too..Its a bravo 3..The barnacles didnt ignore the props either...stuck like glue. I hear it comes off but its some protection for awhile anyway.
Chris1956
Re: Outdrive spray vs Brush on..Please respond
I always thought the brush on was best. You got more paint and protection on the outdrive. I used various paints over the years, however, they kept outlawing the ones that worked best. I ended up using Trilux, which worked OK.
I would not paint the prop, just use the boat more to keep the barnacles at bay. I would only get a few in the "creases" of the prop. You might find some wax for the prop. That might stay in the creases and keep 'em at bay....
