I have just purchased a 1998 chris craft with an OMC/Volvo engine 57FCPBYC. I have discovered that the outdrive tilt leaks down. The drive seems to trim up and down OK, it just slowly lowers by itself. I don't see any external leaks. Is there and easy way to tell if the problem is in the pump or cylinders?
I am leaning towards replacing the pump to see if it fixes it. The pump I have is the one with the reservoir on the top and looking at the on-line parts catalogs, this is part number 3855745. This part appears to be unavailable and the replacement is part number 3587079 which is the pump with the reservoir on the bottom. It appears that there are some aftermarket equivalents (Sierra 18-6806, API marine PT408N, others?) are these OK pumps?
To use this pump, I would need to make a mounting bracket for the pump, replace the electrical connector with ring terminals and make another bracket for the relay. Has anyone done this swap before? Anything else that would need to be done?
Any help would be appreciated.
