Outdrive Water Leak
cbgenrl
I have a 94 OMC 454 and outdrive. Since pulling the boat from winter storage, I have a small trickle of water seeping in where the outdrive enters the transom. I can see the water from the engion compartment and it looks like its coming in through the middle of the outdrive. I am told this may be the result of storing the boat with the drive up (bellows failing as a result). Any thoughts? Also, I have used the boat a couple times anyway to take advantage of the good weather. Should I hold off on future outings until getting this corrected? THANKS!
russthemuss
Re: Outdrive Water Leak
If the bellows are leaking then hold off.<br />When its out of the water loosen the big hoseclamp and gently crack the bellows open.If any water runs out then give it a rebuild-not the whole thing ,just the bellows seals universals etc<br />Keep running and it gets real expensive!
