Outdrive year
FreeBeeTony
Recently purchased a pre-alpha drive s/n 3641917.<br />Can someone tell me the year?<br /><br />Thanks,<br /><br />Tony
Re: Outdrive year
As Stated Before, in your pervious posts....<br />A Mod.1, is a Mod.1....<br />The year doesn't Really Matter.....<br />The Gear Ratio Does....<br />In rebuilding the outdrive, the serial# matters...(for parts purposes)<br />Hanging it on a boat, It Doesn't Matter....
FreeBeeTony
Re: Outdrive year
I under stand a mod 1 is a mod 1, alpha 1 is a alpha 1..........<br />I am just curious as to what year it is.<br />Is there a web site that can help determine this?
Trent
Re: Outdrive year
I 1963 1534570 THRU 1684187 <br />IA/IB/IC 1964 1684188 THRU 1777798 <br />IA/IB/IC (EZ-SHIFT) 1965-1966 1776349 THRU 2065189 <br />120/140 1967-1969 2062141 THRU 2791956 <br />120/140 1970-1977 2791957 THRU 4893634 <br />120/140 1978-1982 4893635 THRU 6225576 <br />160 1967-1969 2065190 THRU 2763441 <br />165 1970-1977 2763442 THRU 4890459 <br />165 1978-1981 4890460 AND UP <br />888 1971-1977 3106717 AND UP <br />898/228 1977 4782330 THRU 4898729 <br />898/228 1978-1982 4898730 THRU 6225576 <br />225-S 1974 3856268 THRU 4200499 <br />233 1975-1977 4200500 AND UP <br />250 1977 4791300 THRU 4898729 <br />260 1978-1982 4898730 THRU 6225576 <br />470 1976-1977 4208730 THRU 4893934 <br />470 1978-1982 4893835 THRU 6225576 <br />485 1980-1982 4893835 AND UP <br />R/MR/ALPHA ONE (Sterndrive) 1983-1990 6225577 THRU 0D469858 <br />R/MR/ALPHA ONE (Transom Assembly) 1983-1990 6216687 THRU 0D469858 <br />ALPHA ONE (GEN.II) 1991-1995 0D469859 THRU 0F679999 <br />ALPHA ONE (GEN.II) 1996-1997 0F680000 THRU 0K999999 <br />ALPHA ONE (GEN.II) 1998 AND UP 0L100040 AND UP <br />I 1963 1534570 THRU 1684187 <br />IA/IB/IC 1964 1684188 THRU 1777798 <br />IA/IB/IC (EZ-SHIFT) 1965-1966 1776349 THRU 2065189 <br />120/140 1967-1969 2062141 THRU 2791956 <br />120/140 1970-1977 2791957 THRU 4893634 <br />120/140 1978-1982 4893635 THRU 6225576 <br />160 1967-1969 2065190 THRU 2763441 <br />165 1970-1977 2763442 THRU 4890459 <br />165 1978-1981 4890460 AND UP <br />888 1971-1977 3106717 AND UP <br />898/228 1977 4782330 THRU 4898729 <br />898/228 1978-1982 4898730 THRU 6225576 <br />225-S 1974 3856268 THRU 4200499 <br />233 1975-1977 4200500 AND UP <br />250 1977 4791300 THRU 4898729 <br />260 1978-1982 4898730 THRU 6225576 <br />470 1976-1977 4208730 THRU 4893934 <br />470 1978-1982 4893835 THRU 6225576 <br />485 1980-1982 4893835 AND UP <br />R/MR/ALPHA ONE (Sterndrive) 1983-1990 6225577 THRU 0D469858 <br />R/MR/ALPHA ONE (Transom Assembly) 1983-1990 6216687 THRU 0D469858 <br />ALPHA ONE (GEN.II) 1991-1995 0D469859 THRU 0F679999 <br />ALPHA ONE (GEN.II) 1996-1997 0F680000 THRU 0K999999 <br />ALPHA ONE (GEN.II) 1998 AND UP 0L100040 AND UP
