outdrive?
73Steury
I just got an early Grady White and I'm trying to ID what kind of outdrive I have. I've never owed an inboard/outboard before. The motor is a Chevy 5.7. The outdrive is painted white with a sticker that says V-6. To raise the drive up and down appears to be gear driven from the left side of the drive if your looking at the transom.
cruzn
Re: outdrive?
If it's white it would be an OMC drive, not Mercruiser. The 5.7 engine is a V-8. The drive is marked V-6???? Does it have a large black rubber membrane around the transom/drive? If so it is an old OMC. What year is the boat? There should be a hull serial number stamped on the upper right corner of the transom. Two of those numbers denote the year of manufacture.
90stingray
Re: outdrive?
Hey 73Steury, pictures my man! They (the pros of iboats) will have your engine, drive, and boat identified in seconds. Give it a try.
