output on rectifier
dcolpitts
have a 1986 140 evinrude, I have a clmers manual but is not helping Whats the voltage from the requlator on the red wire to ground(dc) and the yellow wires fron stator, its a brand new stator, possibly defective? also new power pack, have done output tests Im only getting 12.45 volts at red and ground on terminal strip :(
dcolpitts
Re: output on rectifier
another bit of info, the tach works all the time but if I hit the trim switch the tack drops down then recovers
ob
18 - 20 volts a/c form stator on the two yellow wires.Output of rectifier will be anywhere from 12.5 - 14 volts d/c at higher engine rpms and will vary depending on the battery state of charge.
dcolpitts
THANKS OB, WOULD THE ALARM BEING TOAST BE PART OF THE PROBLEM
