over chargeing
i have a 1992 johnson 60 vro pro series the problem is its charging 16 volts after a couple of hrs running it begins to boil the battery any thoughts voltage regulater maybe?
Rick.
Re: over chargeing
For a minute there I thought it was a new thread about OMC manuals. Glad it isn't Best of luck. Rick.
kybodyman
Re: over chargeing
Now Rick......This guy needs some advice on a charging system.I'm sure someone on this site can help!
petryshyn
Re: over chargeing
If it has a regulator, its likely the problem. If it has only a rectifier, its normal...
emdsapmgr
Re: over chargeing
I have the same engine. Does the same thing. This is normal, as the engine does not have a regulator on it, rectifier only. Have not had any battery issues over the years. Run the radio a lot and keep an eye on the water level just the same.
Re: over chargeing
thanks thats what i needed to know
