Over Greasing Gimbal Bearing
kimbill
The gimbal bearing on our OMC Cobra needs replacing. When the mechanic pulled the outdrive off, exposing the gimbal, I wondered if it was ever possible to over-grease the gimbal bearing? It looked like the cavity could accept unlimited grease.......Until seeing that cavity, I imagined pumping too much grease into the gimbal zerk might come out the distributor cap ...:D ....Now, my neighbors says he pumps and pumps and pumps into the gimbal zerk.........What happens if a 1/2 cartridge was pumped in each year?
Bill
Re: Over Greasing Gimbal Bearing
Ayuh,.... You end up with nearly a 1/2 tube of Grease in the bellows......
I give mine about 20 pumps, about twice a year...
180shabah
Yeah, don't sweat it. just scoop out the excess every fall when you pull the drive.
jerryjerry05
Next time run it on the muffs and pump grease into it while running.8-10 pumps should do it.2-3 times a year.Salt water will need it done more often(just to be sure).Jerry
