Over rpms
mommicked
According to my tinytach (reading half of my rpms:mad:) 450 at idle 3250 at wot. my 03 Yamaha F90tlrb is taching 6400+ at full throttle w 2 aboard, average load. I have a Solas alum. 4 bld. 13x17 currently. I just adjusted the carb pickup timing and the motor runs better than ever. the throttle response is like a hotrod and must be going 40+ at wot, I know its not turning 3250. speed not verified yet. specified range is 5-6000. what pitch would help lower the rpms. boat is a 800lb 1860 G3 jon.
SparkieBoat
Re: Over rpms
IF your current RPMs really are 6400 at WOT. then you should go to a 21 pitch prop 4 blade...this should theoretically drop your RPMs to 5600-5800. you should pick up a few MPH and improve MPG. it will not have quite the jump coming out of the hole though.
