Overall Conceptual Timing Question/Assumption
Demolitron
Hello,
I have a 1974 Evinrude 115 HP Starflite Outboard, model 115493B. I have a question regarding the overall concept of outboard timing.
As a baseline I summarize my existing knowledge of timing. In the automotive world, timing is advanced based on engine RPM and load to allow the fuel/air enough time to burn and reach peak cylinder pressure at around 12-15 degrees ATDC. As the load increases fuel/air density increases is slows down flame front propagation and therefore it takes longer to burn and so timing is advanced to start burning sooner. And likewise, as the RPM goes up there is less angular time to burn so you start burning sooner by advancing the timing.
From what I can tell on my outboard it looks like this, please correct me if I'm wrong or have my setup tuned poorly.
At the idle throttle position, warm-up lever down, the spark advance arm is all the way against the low end stop, carburetor butterflies are closed, and measured timing is just around TDC.
As the throttle control is moved forward the cam follower makes contact with the CAM and the butterflies start to open just as the cam follower center is lined up with the marking on the cam. I have a large mark, then a "start" mark, and then another mark much lower down on the cam. At that point the spark advance arm is forward some and measured timing is at approx 5 degrees BTDC. Here I am assuming that the spark is being advanced but the throttle is just now barley starting to open. On my tune-up sheet it lists this as throttle pickup timing at 5 degrees.
Then as the throttle control is moved forward more the butterflies continue to open, and the spark advance arm moves forward until it hits the high spark advance stop. Now, at this point the throttle butterflies are about 1/3 of the way open. So I have 21 degrees of spark advance at 1/3 of the butterfly opening.
From this point the spark advance is pinned against the high advance setscrew and the throttle butterflies continue to open until they are 100% open.
My biggest question is this... Is this what is supposed to happen? Secondarily, can someone shed some light onto the how and why an Outboard's timing seems so much different than any other engine I've worked on?
Thank you all for your time and sharing your knowledge with me.
JB
Re: Overall Conceptual Timing Question/Assumption
Your analysis is correct, Demolitron.
The synchronization of throttle opening and ignition advance is because two stroke outboards are always under full load, virtually never decelerating or "coasting". They also need high torque upon initial throttle opening. . .no step down from a transmission to multiply the torque..
F_R
The full spark advance with only partial butterfly opening is a fuel saving feature. At that setting, the boat supposedly goes just about as fast as flat out but at reduced fuel consumption.
If you go back about 60 years, some motors did not have the throttle and spark synchronized. You could put the spark at full advance and control the speed with the carb. But they idled very rough unless you retarded the spark. Try opening the carb without first advancing the spark would cause it to fall on it's face. And of course, the spark had to be somewhat retarded to start it without kickback. I only mention this because understanding that bit of background helps explain why the synchronization is so important on today's motors.
