overcharging force.
BIG COL
I have a 1988 85 force u s marine which i think is over charging.The voltage starts off at 12.5v and when you go on to fast idle (2500 rpm)it goes up to 17+ volts.I have fitted a new rectifier and is still the same.I have tested the stator and is less than 2 ohms, could the stator be at fault?I have just checked continuity between the yellow wires and earth and have continuity. is the stator at fault? please help.
