its a 1990 evinrude 60hp the mechanic before me put a impeller in and a new exhaust plate.run the boat all day at 3500rpms no buzzer.you go 4000 then buzzer goes off (yes steady beep).i put in a new impeller and thermastat.same problem,i tried gutting the stat and it ran too cool.it gets good flow thru thermastat hole. the only thing i can think of is i should have put in a complete water pump,the housing looked good so did the impeller.installed a temp but he got the boat up for winter
