77_starcraft
- Joined
- Oct 8, 2007
- 55
1998 Mercusier 7.4 MPI / Bravo I, standard cooling
1) noticed no water out of exhaust, shut down engine before temp got to 190 on dash gauge. No alarm.
2) removed sea pump, impeller missing all blades.
1) replaced impeller, flushed all cooling hoses.
2) removed thermostat housing to inspect for debris. none found, (160 *F t-stat) reinstalled with new gasket.
3) Ran motor on muffs, acceptable flow out of transom exhaust/exhaust boot.
4) continued to run until thermostat temp reached. temp kept climbing, ran until 190 F. shut down.
5) cursed. drank a beer. went to bed
So, the block was partially drained when the circulatar pump hose and t-stat were off, not sure if there is vapor trapped under the t-stat, but each year I drain block and have no problems. The circulator pump bearings seem ok. no leaks.
my plan is to:
1) run it on muff again tonight. prehaps try to loosen bypass hose (manifold to pump) and see if it is full of air.
2) removed t-stat housing and put the whole thing in a pan of hot water. I think the t-stat will be destroyed if removal attempted.
Any ideas? thoughts?
Thanks
my plan is to:
Thanks
