oxbeast1210
- Joined
- May 14, 2010
- 309
1989 Evinrude tracker xp pro 150 hp model : te150slcem
thanks to your guys help ive been able to get me outboard almost to the point that it works just right. The issue I'm having now is that my overheat alarms goes off after Ive been at open throttle seems to be fine while at wot but as soon as i start to throttle back my overheat alarms sounds i also noticed that the water coming from the tale tale alternates between really hot and to about the temperature of the water in the river about every 15 seconds. SO far i have replaced both poppet valves ,both overheat sensors and wiring, both thermostats , and cleaned out both of the water jacket passages which seems to have helped some but my alarm is still sounding Tuesday i will be taking it in to get the water pump replaced i was told by the last owner that he replaced them about 3 months ago but i want to make sure a new one is in there and in there right . I also have an issue with my tachometer the first ten minutes i am in the water it works great but after that it just shoots down to 0 and stays there i don't know if it could possibly be related to the overheat but i figure the more in for the better help i can get
please if you have any thoughts on what else it could be please let me know
thank you
thank you
