Kajun37
- Joined
- Feb 17, 2006
- 348
well i'm out of ideas to fix this problem...maybe you guys can help me out.
1994 Johnson 140 j140txerr
i was given this motor from a guy that repowered because of this same overheat alarm problem...
when i got it mounted on my boat i took it out for a sea trial....when i put it WOT about 43mph....after a couple mins the overheat alarm comes on...i imediately turn it off and pull cover off and touch heads...and find that i can hold both hands on the heads no problem......pisser is peeing great and strong.....i start it up again and go to take off and it ran like crap...latter i find out about SLOW mode.....so this wasnt a problem......i bring it back home and rebuild all 4 carbs, i buy 2 new thermostats and 2 brand new thermo switches. i have the VRO totatlly disabled since i got the motor..capped and unplugged...so the only possible continious alarm will be the overheat alarm..which is controlled by the thermo switch....
today after doing the carbs and replacing the thermostats and thermo swtiches.. i drop it back in water...adjust my carbs according to manual...sounds great....i take off for a run...i run it about 20 mins at 35mph...no problems..no alarm...i decide to take it to WOT at 43mph...a couple mins into WOT the alarm goes off again... i shut down , take off hood..touch heads...i can hold both hands on heads again...not overheating...pisser is working great ....i start and kill it a couple time to get it out of SLOW mode....and take off again...rode around for another 20mins at 35mph and under...purrs like a kitten.......bring it back to about 40mph and the alarm goes off again....
do same checks..not overheating and pisser works...get out of SLOW mode again and this time i ride around for 30+mins at under 35mph.
as much history of this motor that i know...
march04 the guy had pistons resurfaced, new head gaskets
june04 new driveshaft bearing/housing...
may04 new thermostats and thermo sensors
also when i picked up motor the guy tells me he had lower unti rebuilt and new water pump done within last year or so...
compression is 120/125/125/125 ...great spark on all 4..jumps a 7/16 gap
any ideas? :/
any ideas? :/
