Hi,<br />I'm getting my 85 90 EV going after a long time sitting. Did the impellar carb kits and lower unit.<br />I disconnected the VRO and pulled out the tank and wire so I could mix my own. When I went to test the hot alarm by grounding the tan wire on the harness side to the block I got nothing. I know it worked at one time. I cut the lamp cord looking wire that runs from the VRO tank so I could remove it for conversion. Both alarms fail the grounding test. Is it common that the horn will fail? Is there a fuse? I guess I'll have to take the control box off and apply 12 volts directly to the horn to see if it blares. Can anyone suggest an easier way to track this down?<br />thanks<br /><br />H90
