Re: overheat/engine flush
If the impeller was comming apart and you did not find all the missing pieces it very likely that you have a restriction. Usually restrictions occur between the impeller and the t-stat housing. Common places for restrictions are (but not limited to) the fitting in the drive housing where it passes thru the transom (connects the outside and inside supply hose together), power steering cooler (spliced into supply hose between previously mentioned fitting and t-stat), and t-stat housing.
