imported_barlow46
- Joined
- Sep 7, 2006
- 5
Thought we had this one whipped but problem cropped up again today. Engine is 2000 VMax 150 on Hurricane Deckboat...aftermarket gauges. History: Engine has 49 hrs. (all freshwater except for last 10). Water pump was just replaced by dealer after I bought the outfit used and I got my first alarm after boat sat for 6 months. Dealer water tested (30 min) with no alarms. Alarm went off a while back (first trip after dealer service on WP) and RPM's dropped back. Shut engine down and restarted about 10 min. later....no alarm until RPM's get above 3500. Thought I had an overheat problem (see earlier post by Barlow46). Removed tstats and checked in pan of water with candy thermometer. OK. Removed and cleaned popit valve. Checked overheat sensors with water, candy thermometer and digital multimeter. OK. After posting my original problem, it was suggested that I may be dealing with an oil issue rather than overheat since my IR gun was showing no higher than 170's (if I remember correctly on last post). Removed remote oil tank, cleaned, replaced filter. Removed engine oil tank, cleaned, bled system. Also found plastic trim lever on tube under steering housing was broken and replaced it. Trim meter now works. Took out for test run. No alarms! Problem solved...Nope! Went out today and alarm is back. While alarm was sounding, I removed engine cowl and disconnected pink wire on sensor (right bank)....alarm stopped....reconnect wire....alarm continued again. Stopped engine. Removed sensor from right bank and moved it to left bank and put left bank sensor in right bank. Started up agaiin and went to 4000 RPM's. About three minutes into run, alarm starts again. Went back and removed pink wire from right bank sensor,,,alarm stopped...replace wire and alarm started again. I didn't have my IR gun with me but I placed my hand on top of right bank and then left bank. Left bank was cooler, I could hold my hand on indenfinitely. I had to remove my hand after about 7 seconds on right bank, not scalding hot but definitely warmer than left bank. After alarm sounds and engine is dropped down to idle, alarm shuts off after 3 or 4 minutes. Not sure where to check next but want to rule out oil if possible. I have ordered a Yamaha tach with oil/temperature, etc but I have to also put in new harness and switch as Godfrey Hurricane used their "own" harnesses to save a few bucks. I do have the 704 binnacle controls, so I do have that harness. Should I just wait until I get the tach installed and go from there or should I look at some other things while waiting on my stuff to get here? Thanks
