I've got a 1990 Tracker Pro 17 deep V with a 60 hp Johnson that I just serviced the water pump on as well as relocated the tell tale to the top of the head & replaced T-stat & the head gasket. There is no warning buzzer that I can locate anywhere. I would rather have a visual warning than a buzzer, can I just hook a red LED up to that tan wire coming from the temp switch so it would light up when that switch closes & I'll know what's going on? If so can I just tie into the tan wire that went to the vro which has been replaced with a non vro pump? Or should there be a wire in the control box that is tied into that system? If I remember correctly there is a tan wire & maybe a purple wire in the control box that doesn't go to anything. Thanks. Jim.
