Hello kind and wise outboard fanatics! Went fishing today (second time out for the year). At lake #1 the motor started up and ran fine. Trouble at lake #2 - felt the loss of power a couple minutes after leaving the dock. Was obviously overheating, so I shut her down right away. I didn't have time to check the exaust stream, but there were no weeds on the lower unit. Could some other obstructon, or impeller, or pump be the problem? How should I proceed?<br />Unrealted question, I have had this engine for two years now, and under low idle she coughs/spits. I overided this phenomena by applting more throttle, bur now it's time to fix. Is this a carb rebuild issue? Inclosing, would you all weigh in on your opinion of the quality of two cylindar Force engines.<br />Thanks so much for your consideration,<br />Chris
