I recently replaced my water pump on a 1979 4932D, and everything was working fine up until last night.... Ran through some weeds and apparently partially clogged up the intake.
About 15 feet off the dock, the motor stalled out. Turn around, smoke everywhere, stinky gray smoke. The outside engine housing (frame) was too hot to touch. Got it off the boat, cleaned off weeds and pulled lower unit. Water pump looked OK, impeller wasn't damaged. There was a white, foamy, greasy coating all over the inside of the lower unit and shaft housing. The powerhead does not appear to be siezed - it turns freely. Pulled off the powerhead plastic skirt and checked for visible damage. Didn't see any melted parts or anything.
It sure smelled like something got badly burned out. Should I try starting it again or should I tear it down to see what got cooked?
