I have a 2002 Four Winns - 5.7 Volvo Penta GXi
Story -
Forgot to reconnect the hoses to the impeller housing and took it out for the first time this year. The engine quickly overheated and was restricted to low RPM usage. Shut off engine and paddled in.
What I've done so far -
I checked/replaced the impeller - it was toast and most of the fins were gone - only 3 or 4 were still attached, some were inside the housing where the impeller resides, there was one down in the bilge. I haven't found them all, still missing about 5 but I don't think any would be located inside the cooling system since the hoses weren't even attached.
The engine starts fine and runs ok with muffs. I ran it for awhile at idle and then for a few minutes at 2800 RPM and temp seems to be holding fine. The oil looks clean, clear with normal colorization, no water/bubbles etc. I am concerned that there might be additional engine damage, so I pulled the plugs and did a compression check on each cylinder. While doing this, I noticed water in all of the starboard side cylinders. Also, the compression averages higher on the starboard side which I find interesting. Starboard front to back compression is - 155, 160, 160, 145 ; Port side front to back is 135, 120, 135, 130.
I have the overheat diag pdf from Volvo that seems to be referenced in this forum quite often and I'm reading thru that at the moment. So - my questions...
The obvious question - the source of the water leak to the cylinders
Since the compression seems ok, except for the strange average difference port to starboard, does that mean that the head gaskets are probably ok?
I very much appreciate any help given.
Story -
