Overheated???
melbourne
my 1984? 115 johnson ob has been sitting for a while and i finally got the chance to crank it up. of course i hooked the water hose up to the lower unit and the little hole at the bottom was flowing water.
about 4 minutes after i cranked it up the "constant" alarm sounded and i cut the engine off. i let it cool down and cranked it up. i placed my hand behind the exhaust and no water was spraying out of the exhaust.
i have not kept it running long so i'm guessing the alarm or ground is ok
does this mean i have a bad water pump??
any other ideas?
is there a way to test the cooling system??
is there a process i can utilize to determine what went wrong.
thanks in advance
F_R
Re: Overheated???
There is only one way to tell if a water pump is working...put it in the water. A hose isn't good enough because it is forcing the hose pressure through the system. There is one exception: if the hub in the impeller is spun, even hose pressure won't go through. That may be what you have.
