I have a 1984 Sea Ray 245 with marine power 350 325hp and a alpha 1 gen 1 outdrive, now I'm new to boats, but have about 18 years experience in automotive so I know the main engine and mechanics of it, but I am having trouble with it overheating above 1800 rpm otherwise it runs fantastic (except with I forgot to turn the water hose on and ran it dry, will be replacing the impeller and housing tomorrow) but it had this problem before my screw up. I read that I should check the flaps in the risers to make sure they are free, is there anything else I should look for everything seems to check out otherwise, could it be the sea pump on engine and how would you check this? thanks
